Map reading really high.
Old Aug 31, 2024 | 07:44 PM
Yardpro's Avatar
Default Map reading really high.
i am getting closer on my cayman ls3 swap. i have an issue with the MAP. with engine off i am getting a 180 Kpa reading at sea level.. should be closer to 100. this is preventing me from moving forward and doing the first startup.
could this be a wiring issue? any ideas would be greatly appreciated
Old Aug 31, 2024 | 09:01 PM
Defective MAP sensor?? It happens....
Try a new genuine Delco sensor. You never know....
Old Aug 31, 2024 | 09:03 PM
Yardpro's Avatar
this one is brand new.
Would incorrect wiring cause it to read almost 2X high?
Old Aug 31, 2024 | 09:05 PM
Try another new one. Brand new sensors can be bad,
Incorrect wiring would more likely cause non-function.
Old Aug 31, 2024 | 11:52 PM
Full Power's Avatar
Can you verify 0Volt low reference and 5 volt sensor power from PCM ?
Linear 200
Offset 10.33 ?
As noted above, lotta Counterfeit/Low quality/ defective parts in the pipeline many "New In Box"
Old Sep 2, 2024 | 08:51 PM
LilJayV10's Avatar
Is the MAP scaled correctly in the tune(stock PCM) or is the correct MAP selected(aftermarket ECU.
