Oil sending unit location
Old Nov 10, 2024 | 01:13 PM
Omarsvette's Avatar
Default Oil sending unit location
Where is the oil sending unit on my 2011 zo6? And does it communicate with the DIC oil pressure result and the analog gauge?
Old Nov 15, 2024 | 07:28 AM
EDS01SS's Avatar
Drivers side rear of intake(screws into the valley cover) and yes
Old Nov 19, 2024 | 05:40 PM
RB04Av's Avatar
Screws into the block, behind the intake and valley cover.
You don't have an "analog" oil pressure gauge. It's a digital stepper motor driven by the data stream coming out of the ECM. Butt yes, the ECM uses that one input device/sen-sore to generate the data, which it then distributes to multiple "consumers" including of course the gauge.
Old Nov 19, 2024 | 09:21 PM
the_merv's Avatar
Veteran: Air Force
Negative, it's in the Valley Cover. Your other part is correct, it's digital.
