Torque settings on these?
-What's the torque setting on the engine block temp sensor (image below) on the driver side near cylinder 1?
-What is the small star-wrench plug near cylinder 8 (image below)? Since it's finger-tight, what's its torque setting?
Just get them snug...
The temp sensor should have a sealing washer/gasket on it
The plug if I remember right should have teflon or the teflon paste on it, if it doesnt have a sealing washer/gasket
A good torque on things like that is in the 12 ft-lb kind of range. Tight enough butt not too tight. Very technical. There's probably a "spec", since what I just said isn't good enough for a factory setting, butt within a pretty wide range, it doesn't much matter as long as it doesn't leeeeeeeeeek, or fall out, or tear anything up. Common sense goes a long way here.
https://ls1howto.com/index.php?category=1
