Wiring harness issue
Old Aug 30, 2025 | 03:36 PM
Mattyc's Avatar
Default Wiring harness issue
Evening folks I have a dilemma!
I stupidly purchased a 2005-2008 ly6 wiring harness for my ls swap ( 2010 ly6 ) not thinking that it might cause me harness plug/sensor problems!
some of the sensor plugs from the 2005-2008 harness are completely different from the 2010 ly6 engine. i.e cam sensor, oil pressure sensor and possibly the map and maf! I have changed the front cover as I have done a vvt delete and have done a cam and ls2 sprocket!
I was going to change my sensors for new ones so i wondered if i can either change all the sensors to suite the 2008 harness or, change the harness plugs to suite 2010 sensors!
what would be my best option?
thanks in advance!!
Old Sep 4, 2025 | 08:33 PM
Bbknucks's Avatar
Make the harness/sensors match the ecm you are using
Old Sep 4, 2025 | 08:50 PM
rsz288's Avatar
Ditto that. Sensors best to match the ECM (E38?). Making assumption that your LS2 cam sprocket is a 4x & beige sensor, generally different cam sensor connectors depended on whether there was an extension harness involved from the cam sensor down to the oil pan level.
Oil pressure connector/sensor changed for 09.
Is MAP on engine a Bosch?
Any pics on what you have?
Old Sep 4, 2025 | 08:55 PM
Mattyc's Avatar
There's actually been a small development since I posted this, the company that supplied the harness has actually offered to exchange it on my dime ( postage ) and send me a new and correct harness. So I think im out of the woods for now!
Thanks for the response though 👍🏻
Old Sep 4, 2025 | 09:42 PM
rsz288's Avatar
Great outcome 👍
