Exhaust port matching
How important, useful, _____________?, is it to match the mouth of the exhaust port to the header?
What are the benefit(s)?
Thanks!
If money is no object they are the best you can get for a broad power band with a bigger cam, but reality is you can get 80% of the benefit just by sticking a header flange size significantly bigger than the head port all the way around - esp the top. That helps reduce reversion as mentioned above. Not as good, but a lot cheaper as most decent headers come larger at the flange anyway.
Pretty much any production vehicle will have to have a semi-tight bend radius off the head to clear other parts. (Suspension, body, fenders, etc.) A larger tube will obviously flow more thru the bends. I have noticed that a lot of designs have far tighter bends than needed, and suspect this is due to materials/manufacturing commonality. Its easier to make a shitload of headers if there is only small changes made from one version to the next.
However, if we are talking about the best header design… yes an exact match, with the least bend radius, stepped after 7-8”, and a tri-y construction has been proven to make the most power under 8k rpm.
some really good reading on this regarding “blowdown” length:
https://www.speed-talk.com/forum/vie...df1233ffffa53e
On page 7, they did talk about the Tri-y headers which I run, because they were the longest--- how be it that they are the older Thorly midlength headers, that I could fit on my 4 wheel drive truck that the exhaust pipe would tuck over the cross member so that I would not lose ground clearance.
As you can tell, plenty of ground clearance on my lawn mower also! [ Avatar]
Allways interested in reading about the "Try-y" system.
Last edited by Metalchipper; Oct 13, 2025 at 10:52 AM. Reason: adding more nonsence
Originally Posted by Metalchipper
Better to have larger ports on the manifold side. Helps with anti inversion flow. You don’t want the exhaust pluses back flowing into the head.
Quote: SteveJewels
I think the supercharger pretty much takes care of that. Scavenging is not really a thing with air being forced into the cylinder during valve overlap.
How much supercharger pressure do you have at idle? Same as atmospheric, same as a NA engine, right? Unless your supercharger is set up to provide boost at idle.... which.... how would I know that.
Reversion is greater at idle and slower RPMs.
Do you want combustion residue, [carbon residue] to flow back into the intake path? At some point in the exhaust cycle, cylinder pressure approaches atmospheric pressure. Reversion will happen then.
Just trying to help.
I want to replace the engine in my 2008 Escalade.
I have a 2026 engine (Escalade engine) that needs some "mods".
Would you like to help ?
Lance
It would be a honor to try to help. But I do not know how much help I would be. I am pretty much "old School"! Currently working on a 1956 Hudson Hornet 308, 6 cylinder flat head motor to replace my Dad's 1952, 308 that he installed in his 1946 Hudson Super Six Coupe.
I am sure that others here on this forum would have more current knowledge than an old fart like me.
How could it be otherwise? I can't imagine there being enough material in the head to be able to make the exhaust port volume larger then that of the intake ports.
The head are DART Pro1 280's. The intake port volume is 280 cc's.
I dont know the exhaust port volume but the intake valve diameter is 2.165" and the exhaust is 1.6". I would assume the corresponding port volumes to be commensurate.
[QUOTE=Steve]
"How could it be otherwise? I can't imagine there being enough material in the head to be able to make the exhaust port volume larger then that of the intake ports.
I dont know the exhaust port volume but the intake valve diameter is 2.165" and the exhaust is 1.6". I would assime the corresponding port volumes to be commensurate."
OK, who said anything about matching the intake ports with the exhaust ports?
Your question was "is it to match the mouth of the exhaust port to the header?"
OK, I used the words " manifold side" maybe I should of used "header" or "exhaust manifold" or " exhaust header manifold" or "the part that bolts on the exhaust ports".
Hope that clears things up.
Yes it has hydraulic lifters. We are goining to take a chance that they will work. The 308 is what we pulled out of a donner Hornet, was a replacement motor with few miles on it, just sludged up. I think they used the oil pan to collect the contaminates that would drop out of the oil!
It is the two carb intake [ H ], my brother and I want to get it running first, as there is some body work and the interior is shot.........they we can upgrade the engine later if needed. Our Dad used it to haul his race car to the track. But has not ran for 65 years? Also it has the smaller 1946 9" clutch so we do not want to push it too hard. For now it is going to get rings, crank and rod bearings, porting, valve job and OVH accessories. Had to get the 1952 crank ground because the 56 came out of a auto-trany and was 1/2" too short. So, no on the 262 or Clifford head for now.
I wonder what forum here would be the place for "Hudsons"? The car they built too good!
Thanks for asking.
They are about an hour or so drive so I can pick up the engine and drag it back to Dayton.
