Water pump
Old Dec 31, 2025 | 07:14 PM
SteveJewels's Avatar
Veteran: Navy
Default Water pump
What is the recommended water pump?
Sleeved 5.3L, dressed out to replace the LS3 in a 2010 base Vette. 427, maybe 10PSI boost from a CSC.
Thanks!
Old Jan 1, 2026 | 07:36 AM
Double06's Avatar
The OEM Corvette pump is not too bad. Edlebrock makes a good pump with the outlet on the drivers side like your Corvette. The Edlebrock water pump also has a very wide water pump pulley for belts which is good for you blower guys. The key with the Corvette is a good fan set up. Dewitts now has a dual 11-inch brushless fan system that flows 30-40% more than the old brushed system. Draws 40+ amps compared to the old 30 amp brushed system.
Old Jan 8, 2026 | 07:51 PM
Veteran: Navy
I am fighting cooling so I'm thinking the Edelbrock.
Old Jan 9, 2026 | 12:37 AM
DualQuadDave's Avatar
Radiator is biggest part of the cooling equation. Put the biggest/baddest you can fit.
Old Jan 9, 2026 | 03:50 PM
Veteran: Navy
When the SC was added the thing was to use a short radiator. I have heard (but not seen) a full sized radiator can be fit under the A&A tube from the aftercooler to the TB.
Old Jan 10, 2026 | 02:59 AM
Vokes's Avatar
Edelbrock works for me
Old Jan 11, 2026 | 08:44 AM
Double06's Avatar
The new dual 11 inch brushless fans from Dewitts might work also. Being only 11 inch you could put them on the lower side of the radiator - not sure how tall your core is.
