PCV is confusing lol
can I just run both valve covers to a breather tank?
motor is iron 6.2 with .630 cam 225 heads fast 92 42lbs injectors
Breather can or just sealed ? Any vacuum on the can ?
I was thinking of using a T for both valve covers , then to intake for vacuum…
there’s just so much different info out there , and guys with the older hollies seem to be sucking oil into the can rapidly
Those are two different ways to ventilate the crankcase. One uses a breather can or cans which has an air filter on it and is merely a system designed to relieve the pressure in the crankcase by emitting the crankcase vapors into the atmosphere and the other is a can without an air filter also known as a sealed catch can which is used for PCV systems where the crankcase vapors are sucked back into the engine by the intake manifold so it can mix with the fresh air coming in from the throttle body to be reburnt. A cleaner way to deal with the crankcase emissions but it does lead to deposit buildup inside the engine over a period of time. In that video he's incorrect. That PCV valve looks to be threaded and has an o-ring meaning the sealed can can accept that PCV valve and the nipple is where you would connect the hose to the intake manifold port not the valve cover.
Mighty Mouse Solutions has many different types of setups depending on what your looking to do so there's that option as well.
Hope this helps ..
Hope this helps ..
no check valves ect just vent the pressure
For proper PCV, you first pull fresh air from the air intake AFTER the MAF (if used). Route that line to an unrestricted valve cover hose nipple. That clean air will then go thru the engine picking up all kinds of nasties as intended, making its way to the opposite valve cover with either a restricted nipple or PCV valve. From there to either a catch can and then a manifold vacuum source OR straight from valve cover to manifold vacuum source. DONE.
Notice the 10AN on the passenger and the other 10AN line on the drivers side valve covers? Those both connect to the Moroso breather can shown in the image. As for the intake manifold and throttle body they are capped off.
question about that can. Does it have internal baffling ?
some say we need to pull the vapors out with vacuum, other say it pulls the oil out. With a good baffling system that won’t happen. I do think I’ll run two check valves that allow air out but none in.
here’s the proof from motion who knows better than most of us Here I’d argue
I have LS9 valve covers. Two 10AN breather fittings. 10AN Y to single 10AN into the side of a MightyMouse catch can. Their remote exit lid on the top going down to an exhaust extractor with a 0psi check valve in between.
