LS2 Intake vs. LS1 Intake
Old Dec 2, 2009 | 11:54 AM
BrownBoy's Avatar
Upon furthur research, I found these dyno comparisons:
http://www.ls1gto.com/forums/showpos...48&postcount=1
Old Dec 2, 2009 | 12:28 PM
MonmouthCtyLS7's Avatar
Good Stuff.
Old Jan 26, 2012 | 11:12 AM
C6Antwon's Avatar
Good thing I didnt buy and LS2 intake for my swap, the LS1 was only $30
Old Jan 26, 2012 | 05:24 PM
Pumba's Avatar
Originally Posted by C5 Forever
Well, with results posted of how the LS2 compared to an LS6 and FAST 90; what are it's gains over a regular LS1 intake? I'm asking because my LS2 is ordered and I already have my cam here and am saving up for Stage II heads. Should i just try to sell it now and get an LS6; or go with it, because it will be an upgrade from an LS1?
The LS6 intake manifold is a very strong piece. It is a much better manifold for a stock, slightly modified, or all out cathedral port LS engine, IF you send it to TPiS and have them convert it to use a LS2/LS3/LS7 90 mm throttle body.
I had mine converted and with no other changes, except tuning, my bolt-on only LS6 showed the following improvements. Yes, my engine was tuned before the installation of the 90 mm throttle body:
TPiS, the company that does the conversion of your LS6 manifold also did some back-to-back testing of a convertered LS6 - 90 mm manifold versus a 90 mm F.A.S.T. manifold on a highly modified LS engine:
The price of the TPiS 90 mm LS6 manifold is approximately $350, with your LS6 manifold as an exchange.
Old Jan 29, 2012 | 12:12 AM
jegten's Avatar
^^+1 i did the same with my LS6 intake. i sent it to TPiS. the price is just right.
furthermore, i put a NW 92mm tb against the snout, and it was not that much to make it match.
i did a lot of research, and also came across the above table of TPiS's back to back test. this led me to getting the ls6 intake modded by them. great people to deal with as well.
i ran it with the 92mm on my 418, and with cyl 8 leaking coolant, it dyno'd 507/484, with 450 rwtq at 3k rpm!
imo, and honestly, i think this is the way to go.
Old Jul 4, 2012 | 03:02 AM
DiabloSS's Avatar
LS6 Intake with a 90mm ported tb opening it is on a 92mm TB.... Thanks
Old Jul 4, 2012 | 04:42 PM
bww3588's Avatar
Wow. Way to bring back a 8 year old thread to debate that the Ls2 intake is junk.
Old Jul 4, 2012 | 05:46 PM
offaxis's Avatar
Yep and that stock ls1 intake is crap too
LS6 or fast are the only way to go if you arent going carb style
Old Jul 4, 2012 | 06:06 PM
DietCoke's Avatar
Old Jul 4, 2012 | 06:28 PM
offaxis's Avatar
ya cant say they arent using the search button
Old Jul 5, 2012 | 12:47 PM
Johnnystock's Avatar
Originally Posted by DietCoke
hahahahah
Old Aug 23, 2016 | 12:30 AM
  #32
crmd37's Avatar
Well, I guess since I've been researching this I might as well bring this thread back to life for one quick piece of info. Also, it's only gone 4 years untouched (since 2012) instead of the previous 8 years before someone became the "Thread Digger". I guess it's my turn now lol...
http://www.hotrod.com/articles/20-ls...ifolds-tested/
Same motor tested with 20 different intakes. View at your own risk haha
Old Aug 26, 2016 | 08:44 PM
  #33
big hammer's Avatar
Lol awesome
