Right side valve cover on the left side?
Old Feb 23, 2007 | 07:25 PM
valsperformance's Avatar
Default Right side valve cover on the left side?
Does anyone know off hand if the right side VC with the oil fill hole will work on the left side? I would like to run dual screw in filters on each side to vent the crank case. It is a 408inch stroked LQ9 engine if it matters.
Old Feb 23, 2007 | 09:24 PM
Brandon Boomhauer's Avatar
well, it would put the oil fill hole at the back left of the engine...
But it will bolt up.
oh and the engine doesnt matter, if anything the heads would (or the rockers you are running more importantly)
Old Feb 23, 2007 | 10:08 PM
That is what I thought. I will actually be running 2 right side covers to take advantage of those nice screw in steel breathers..It will make it easy to change or clean them..
