L76 vs FAST 90/90
Old Mar 13, 2007 | 02:52 AM
transamman400's Avatar
Default L76 vs FAST 90/90
simple question...what is the best possible intake i could buy for my 98 m6 TA. from what ive read these two are the best. right now my car makes approximately about 430 rwhp and am looking to make 450 rwhp AND torque. set up is:
Agostino Heads 296cfm @ .600 intake & 234 @ .600, Comp Cam XE-R 236/236 @.50 .602/.602 @.50 110LS, LS6 Intake, Ported TB, 30lb inj, Whisper Lid, Fast Toys Ramair, March underdrive pullies, Comp R lifters, Flowtech Longtubes, X-Pipe, Dynomax bullets dump @ axle 3.42s
Old Mar 13, 2007 | 03:00 AM
Quickin's Avatar
Don't think you'll make 20 RWHP with either intake, unless you have a big cube engine. Maybe close.
Old Mar 13, 2007 | 09:54 AM
SideStep's Avatar
Are you changing heads also??? The L76 intake runners are square (rectangle) not cathedral, if I remember right...
Old Mar 13, 2007 | 10:09 AM
2c5s's Avatar
Correct, the L76 works on L92 heads, not traditional LS1 cathedral port heads. That's strange, calling a LS1 traditional!
slt200mph's Avatar
That is not the correct intake for your heads .. the FAST 90/90 combo if it is ported will get you 20-30 hp depending on the motor. See Ron @ Vengeance for a ported FAST 90 intake..
Old Mar 13, 2007 | 07:16 PM
mike c.'s Avatar
i gained 23hp(stang dyno) from a only a mild clean up port on my fast 90mm on a 346ci motor..
Old Mar 14, 2007 | 02:16 PM
Jefro6996's Avatar
Did you do the port yourself on your fast 90 or did you have someone port it for a 23hp gain??
Old Mar 14, 2007 | 02:18 PM
MrDude_1's Avatar
well, one intake fits, the other one requires heads that dont fit on what im assuming is still an LS1 shortblock... so you dont really have a choice... 90/90 or keep your current LS6.
Old Mar 14, 2007 | 05:34 PM
Hard Core Z28's Avatar
The fast 90 is designed better, but if you are running a L92 head then the fast wont work for you.
Old Mar 14, 2007 | 05:38 PM
mike c.'s Avatar
JEFOR6996-i did it my self w/a dremmel tool. i only cleaned up the area where that lip is in the lower runners. i then hand smoothed it w/fine sand paper. it was easy,but i took my time so not to take off too much and ruin it.
Old Mar 14, 2007 | 07:17 PM
Jefro6996's Avatar
I just put my fast 90 on and saw how there is a lip on thre runner. I thought about doing it but got lazy and just threw it on. Next time i get bored ill probably do the same thing. thanks for the info.
Old Mar 25, 2007 | 12:33 AM
NemesisC5's Avatar
Old Mar 25, 2007 | 05:30 PM
pdd's Avatar
pdd
thats a great gain bro!!
