MAP Sensor for L76
Old Mar 21, 2007 | 09:43 AM
the_merv's Avatar
Veteran: Air Force
Default MAP Sensor for L76
Anyone know how to do this.. what MAP Sensor do you use for the L76 Intake, and how do you wire it(if there is any modifications). I am using a 1999 Camaro LS1 Harness.
Old Mar 21, 2007 | 09:51 AM
See5's Avatar
Use LS1/6 just extend the wires to the front of the manifold.
Old Mar 21, 2007 | 09:56 AM
BLKWS6's Avatar
i believe a couple of sponsors also make a plug-n-play harness for it also so you dont have to cut/splice the wires.
Old Mar 21, 2007 | 10:31 AM
the_merv's Avatar
Veteran: Air Force
Thanks, that takes care of that.
Wiring doesn't bother me..I re-wired the Harness I have to go in the car. Anyone have a pic of what Plug it exactly is?
