L92 Valve Covers
Old Mar 21, 2007 | 11:23 AM
the_merv's Avatar
Default L92 Valve Covers
I am sure this has been discussed.. I haven't found anything on it. What Valve Covers will work on a L92 Head. I got a good deal on a pair of LS6 Covers, looking into them..
Old Mar 21, 2007 | 11:39 AM
WKMCD's Avatar
I think you can modify the baffles in the centerbolt valve covers.
This is what I did for the L92's.
Old Mar 21, 2007 | 11:54 AM
Quik's Avatar
yes i modified the baffle in mine to work
Old Mar 21, 2007 | 12:11 PM
the_merv's Avatar
What exactly did you guys do..
Old Mar 21, 2007 | 01:42 PM
Quik's Avatar
you need to grind the baffles to clear the rocker arm. nothing a dremel wont take care of
Old Mar 21, 2007 | 01:48 PM
the_merv's Avatar
Cool, thanks.
Old Mar 21, 2007 | 05:52 PM
VortechC5's Avatar
Are those valve covers baffled for the breathers?
Old Mar 21, 2007 | 06:33 PM
See5's Avatar
Later LS2 covers work also. It seems the driver's side is ok and early LS1s have the baffles that hit on the pass (fill) side.
Old Mar 21, 2007 | 08:04 PM
adams2003's Avatar
Grinding the baffle wont effect the oiling system?
Old Mar 21, 2007 | 10:28 PM
Quik's Avatar
no since all it does is have the vent for the pcv. elimnate them and use breathers and your fine
