Fuel
Old Mar 23, 2007 | 09:14 AM
the_merv's Avatar
Default Fuel
You guys with the L76 Intakes.. what are you running for Fuel Rails and Injectors? I just bought LS2 Injectors, and I know I am going to need LS2 Rails, is that the recommended setup?
Old Mar 23, 2007 | 10:43 AM
8ty8 LS1's Avatar
yes more info plz
Old Mar 23, 2007 | 12:15 PM
rocketman69's Avatar
Depends on how much fuel you're going to need. The stock L76 injectors are the same part number as the LS7s and are rated at 40 lbs/hr. They use the LS2 rails as well. I believe the stock LS2 injectors are rated at 34 lbs/hr.
Old Mar 23, 2007 | 01:50 PM
the_merv's Avatar
Just building a NA 402, pretty decent Cam.
Old Mar 23, 2007 | 07:30 PM
Quik's Avatar
i running a ls1 fuel rail with svo42 injectors
Old Mar 24, 2007 | 11:01 AM
WKMCD's Avatar
This is my setup.
Old Mar 27, 2007 | 11:16 AM
8ty8 LS1's Avatar
how much were those FAST rails?
Old Mar 28, 2007 | 07:45 AM
WKMCD's Avatar
The whole setup with fittings, hoses, rails and regulator was about $550-600 as I remember. I have a return style fuel system and need the regulator. You may not.
