Head Gasket Help !!!!
Old Mar 30, 2007 | 08:19 PM
408SSA3's Avatar
Default Head Gasket Help !!!!
Ok here is where im at im building a Iron 408 with eagle 4" Crank, eagle 6.125 H beam rod's and JE 4.30 flat top's with -2cc valve reliefs cut in them. i put the #1, and #2 rod's and pistons in and i had .43 of my pistons sticking out of my block and im runing the cosmetic .45 head gaskets and i can only find .53 thickness gaskets. what should i do ?
Im runing the L92's and the L76 Intake with this motor and a custom comp cam 248/258-646-646/113+3
Help Me Out Here Guy's
Old Mar 30, 2007 | 08:20 PM
brad8266's Avatar
cometic can do a custom gasket if what you want isnt normal stock.
Old Mar 30, 2007 | 09:00 PM
bigdsz's Avatar
For starters, I believe you mean .043 and .053. Was your block decked? Erik is building a 408 for me and he decks the block, but with that the pistons are only out .010. Stock is .005-.007. You have big problems IMO if the pistons are in fact out that much.
Old Mar 31, 2007 | 05:02 PM
408SSA3's Avatar
Eagle sent me a 4.100 crank instead of a 4.000
I'll have the new one by friday
Old Apr 1, 2007 | 02:27 AM
pewter 01 SS's Avatar
you can try the sce gaskets. i had to a .065 think because mine came out 0.030 out of the hole.. i think they even have like .075 think gasket. you want at least .030 of clearence between the valves and pistons.. good luck
Old Apr 2, 2007 | 11:34 AM
moeZ28's Avatar
Yeah, he meant 4.030" bore as well...come on man, get your 0's in the right place...
Anyway, problem solved...He was sent a 4.100" stroke crank, instead of the 4" stroke he ordered. They are replacing it and all is well now. This should be one hell of a strong motor.
Old Apr 10, 2007 | 10:35 PM
heymoej's Avatar
sounds like it is gonna be a monster,
