HOW TO DISTINGUISH an L92 head?
Is there a specific casting # to look for or any part # to look at on the head off the 2007 CADILLAC ESCALADE's??, any info would be great??
THANKS in ADVANCE!!!!!!!!!!!!!!!!!
Hm, I was under the impression that all 07 'lades had the L92 head. I do not know about visual cues that it is an L92 head, but the part number is 12582714. You can get them at pretty good prices new. Check out SDPC, they can get them for you with upgraded springs to .650 lift for 800ish.
What is the difference between the two casting numbers???? i have no knowledge on the L92 stuff but i would think its only one number since its only been out on one or two vehicles so far...???? Thanks for the quick response by the way you're the man
My understanding is that there are at least three casting numbers made for L92 heads and that the two mentioned above are the regular production heads. (One was a pre production). You can search through the SLP posts to get a bit more info on the difference between the two available castings. One is considered a "bare" casting and the other is considered a finished one. As I understand it, it seems to have more to do with the surface texture of the two heads. There are other differences between the intake port cores of the two castings but they are relatively minor.
Hope this helps.
Richard
Hope this helps.
Richard
