Can Fbody lS1 brackets and acc. used on LS7 ?
Old May 3, 2007 | 06:32 AM
Bowtiejoni's Avatar
Default Can Fbody lS1 brackets and acc. used on LS7 ?
As title said , can f-body LS1 ps-pump,alternator,ac compressor and brackets used on LS7 crate engine??
Old May 3, 2007 | 07:23 AM
bowtiguy's Avatar
it took the right people to ask.... but Jason at katech used 2002 F-body accessries on his motor, I will be doing tehsam eon my 7.o LS7block when I squeeze it into my 94 B4C car. I'm pricing out all new gear from my local chevy dealer but most of the items will be autostore bought to keep costs down, and the PS pump will be aftermarket along with the ATi balancer.
Old May 4, 2007 | 12:21 AM
Bowtiejoni's Avatar
Okay i know they "bolt" on to block but is the balancer / LS7 water pump is same line with Fbody accesorys?
Old May 4, 2007 | 01:02 AM
bowtiguy's Avatar
I believe the balancer is different when using the ls7crank. katech has the Ati version for sale at $500, ATI now has a part number too. from what I've been told either the ls1 or ls2 water pump will work.
Old May 7, 2007 | 07:10 AM
Bowtiejoni's Avatar
Why orginal LS7 waterpump cant be used ?
Old Jun 9, 2007 | 12:58 PM
Bowtiejoni's Avatar
ttt..
Old Jun 10, 2007 | 10:15 AM
John B's Avatar
Moderator
Katech did...I just used the C5 accessory drive on mine.
Old Jun 10, 2007 | 10:59 AM
bowtiguy's Avatar
Talked with jason from Katech for a bit and he said go ahead and use the-body 98-2002 LS1 accessories, bolts right up to the LS7/LS2 block. I'll use the LS7 front cover, dry sump pump and an aftermarket power steering pump, E-bay 160 amp alternator, and a GM A/C pump. I'm doing a complete LT1 to LS7 swap so I need everything....PITA but for current LS1 guys this swap should be easy. For me it means new radiator, air intake, BMR K member, LS1 plastic tank, and radiator.
according to Steve at R.E.D. and some other threads I've read lately, you can even run the dry-sump system on the LS2 and save some $$$ on a darton resleaved LS2 vs. LS7 block. you just give up the billet mains that are not transferable to the LS2 from the LS7.
Old Jul 2, 2007 | 05:51 PM
89TransAmWS6's Avatar
Out of curiosity why would you have to swap fuel tanks? Are you thinking evap or something? John B swapped one into a monte, did you need to modify your fuel tank?
Joe
