Do I need bigger primaries???
Old May 13, 2007 | 02:55 PM
adams2003's Avatar
Default Do I need bigger primaries???
I am currently having a 457 lsx built for my 03 silverado ss. I currently have pacesetter LT with 1 3/4" primaries and 3 inch collectors. At this time 1 3/4" primaries are the biggest available for my truck. I am wondering if custom headers with maybe a 1 7/8" primary or even a 2" primary would be benifitial to me. I am thinking they would, but I am also thinking that maybe the 1 3/4" primaries will give me more back pressure creating more torque to get my 5,300lb beast moving. I just want to make my truck as fast as possible. Any help would be appreciated. Here are the specs on the motor:
LSX block
-LS7 heads (stock intake side, but the exhaust has been reworked by WCCH)
-Ported LS7 manifold (jeremy Formato)
-4.200" bore
-4.125" stroke
-6.125" rods
-Custom CP pistons with a reverse dome of the ls7 combustion chamber
-SCR of roughly 11.2:1
Old May 13, 2007 | 04:03 PM
71CamaroLS1's Avatar
Optimum header pipe diameter depends on a bunch of different factors. The basic tradeoff with header primary diameter is that smaller diameters produce stronger scavenging pulses, which increases volumetric efficiency, torque, and horsepower - but if you get too small, backpressure on the exhaust stroke begins to take away more power than is gained by better scavenging, particularly at high RPM.
Something to consider: the exhaust valve on an LS7 is 1.60 diameter. The actual port diameter at the valve bowl is less than that, below 1.5 inch. The exhaust port is about 1 5/8 inch wide at its widest point. Putting a 2 inch header on an exhaust port like this is just a waste - the exhaust port will never flow enough to use the flow capacity of a 2 inch primary, but the intensity of the scavenging pulse will be reduced and you'll probably lose both torque and top end power.
Just my personal opinion, given that this is a truck, is that your existing 1 3/4 primaries are probably a pretty good tradeoff between mid range torque and top end power.
Old May 13, 2007 | 04:16 PM
adams2003's Avatar
Hmm....that makes sense. Would you still have that opinion if I told you my ls7's flow 250 cfm @.600 lift on the exhaust side after porting?
Old May 13, 2007 | 05:30 PM
My guess - and it is just an educated guess - is that you will get more power under the curve with 1 3/4 primaries, unless you're going way big on the cam. And going way big on the cam would probably be a mistake in a 5,300 lb truck with (I assume) an automatic tranny.
Just another point to consider - exhaust flow at .600 lift is actually not as important as exhaust flow below .200 lift. Most exhaust gas is leaves the cylinder during exhaust "blowdown", within 50 - 70 degrees of crank angle after the exhaust valve begins to open on the power stroke. The rest of the exhaust gas is "pumped" out during the exhaust stroke - higher lift exhaust flow does help here.
FWIW, the LG motorsports guys are building 600+ RWHP LS7s with ported heads in 3100 lb M6 'vettes, and they're still using 1 3/4 primaries on their headers. Given the economics of the Z06 customer base, if LG could show 15 HP more from a 1 7/8 primary and charge $1K extra for it, they'd do it ...
Old May 13, 2007 | 09:41 PM
adams2003's Avatar
Wow, I wasn't aware the lg is using 1 3/4" primaries. My cam will most likely be in the mid to high 230's on duration.
Old May 15, 2007 | 01:58 PM
adams2003's Avatar
Any body else have any comments or opinions?
Old May 27, 2007 | 06:04 AM
KOOL C5's Avatar
I have a comment/question. I put a stock LS7 in my 97 C5 with 2 inch Headers and went back to 3.15 gears for street. It ran a couple of 10.70s @ 125mph a few weeks ago. I was shocked that it ran so strong for a stock engine in a 3500 lb car. My question is, did I waste my money on these Headers and would it be better to put smaller headers back on?
Thanks for any help.
Old May 27, 2007 | 10:09 AM
It would be impossible to tell without swapping the old headers back on. If it works that well, I wouldn't mess with it.
BTW, where did you get 2" headers?
Old May 27, 2007 | 11:33 AM
KOOL C5's Avatar
[QUOTE=
BTW, where did you get 2" headers?[/QUOTE]
Stainless Works has them. They are a tight fit.
Old May 27, 2007 | 11:41 AM
Quik's Avatar
hoenstly with a motor that large torque isnt an issue. and with a motor that large i would want something that can flow well up top. most ppl with larger cubed motors are seeing good gains by going from 1 3/4 to 1 7/8s. hell i think even stock LS7s run
1 7/8 headers so why even think of running smaller
as for a 1 7/8 header i have them on my truck and im sure they would work on yorus as well.
IMHO your leaving to much on the table in your setup with 1 3/4s
