timing set for LS2?
Old May 26, 2007 | 11:46 AM
JDP's Avatar
JDP
Default timing set for LS2?
search isnt working, what a suprise.
im looking to see what i should go with for an LS2, i dont know if a stock timing set is good enough, or if i should go with something like SLPs double roller or the double roller from JP Performance that i found on SpeedInc.
just trying to get all my parts together for my build
Old May 26, 2007 | 12:11 PM
JDP's Avatar
JDP
whoops, should have put this in internal i think
Old May 27, 2007 | 03:00 PM
JDP's Avatar
JDP
nobody?
Old May 27, 2007 | 06:23 PM
JDP's Avatar
JDP
ahh...
you guys suck
Old May 28, 2007 | 06:13 AM
Los Angeles Pi's Avatar
After going through this myself, I went with the Rollmaster hardened single chain and gear set.
The LS2 chain is an upgrade for the LS1. So I figured single was best, especially a hardened aftermarket.
I was told but have not experienced that something has to be ground for the double chain to fit.
About to do the head/cam swap myself and will know more when i am done. Of course.
