tko 600/ ls7
Old Jul 3, 2007 | 12:07 AM
kps's Avatar
kps
Question tko 600/ ls7
Has anyone here installed a tko 600 behind ls-7(7.0l) in particular bellhousing,input shaft issues,etc? thx
Old Jul 3, 2007 | 12:29 AM
Project GatTagO's Avatar
Same as a TKO behind any Gen III/Gen IV engine. Been covered many times.
Andrew
Old Jul 3, 2007 | 08:55 AM
kps's Avatar
kps
Default ls-7 tko
Ok,I will look further into it here,tried using "search posts" with "ls-7/tko" as phrase and didnt get much info.thx for reply tho
Old Jul 25, 2007 | 11:33 AM
pcf_mark's Avatar
Remove and discard the pilot bearing (ball bearing) in the LS7 crank and replace with any standard GM pilot bearing (needle roller or bronze). Otherwise you can not get the transmission to bolt up.
