FAST 90 intake on a gto ls2 question.
1. you need to either get some offset brackets or even some big washers to hold down the fuel rail (fuel rail wont line up but its close to fitting)
2. you need to either get a extension harness, or cut back on the wire loom and move the map sensor to the rear of the manifold.
3. you will need to get some nuts for the tb bolts, there is now thread holes, you need to just put the bolt all the way through and put a nut on it.
4. you need to transfer your top cover bolts from your ls1 car to your gto.
that about it, it physically bolts your heads and everything. pm if you have anymore questions.
I spaced out the power steering tank about an inch with some longer M12's I have the old 4 door GT8 equiv of the gto/monaro.
