What pistons would i need for LS2
#2. What is the Exact Size of the Stock Rod where the Wrist Pin connects to the Piston? So that Whatever New pistons i get The new pistons Fit The Wrist Pin to the Stock Rod ?
#3 What is the Spec From the Center line of the Crank to the Top of the Block ? The full stroke
#4 What is the Size of The Rod Bearings That i need ?
#5 What Size Bolts do i need for the Stock Rods ?
#6 Where can i find the Torque Specs on the Rod Bolts ? And All the Torque Specs For the LS2 Engine For all the Bolts ?
#7 What Forged Pistons Would you Prefer ? Wiseco ? Speed Pro ? JE ? Eagle ?
