LS2 408 Engine build.. looking for 550-600RWHP,,
New LS2 GM Perfomance Block
Eagle 4.0" Stroker Crank
Clevitte H Series Main Bearings
Clevitte H Series Rod Bearings
Speed Pro Competion Cam Bearings
6.125 Eagle 4340 H Beam Rods
ManleyForged Pistons -6cc
Total Seal File to fit Plasma Moly Piston Rings
GM Performance L92 Heads with Custom Stainless Valves and .620 springs
Cometic MLS Head Gaskets
Custom Ground Camshaft
LS7 High RPM Lifters
Lifter Retainers & Bolts
4340 3/8" .080 Wall Pushrods
L92 1.7 Rocker Arms
Melling CNC High Flow Oil Pump
HD CTSV LS2 Timing Set
Haven't decided yet on going EFI or GMPP carb intake with a bo laws built carb.
I would like to attain 550RWHP or more. Is this possible with this setup?
I haven't picked out a cam yet. Any suggestions please?
Say I want to put a 75 or 100hp shot of nitrous. Do I need to build anything different?
Forced induction?
What would be a reasonable number to expect from that build so far?
Call HKE racing engines. They use an LQ9 block not the aluminum. I dont see 550 out of range with a real good set of heads. It happens down here in Tx all the time.
If it is a little shy nothing that your 100 shot cant bump up easily. Last edited by Stang's Bane; Jul 24, 2007 at 03:41 PM.
WTF did you just say? LOL
I agree on the first half. Track times will be lower with an aluminum block with the weight difference but not much faster.
However, the poster asked about horsepower which would interpret that he is looking for dyno numbers/ aka iron block
IMO use an iron block, and tell them you want to spray 250-300 to it. Its not going to change much other than pistons. I guarantee if you start out with a 75-100 you are gona wana keep pushing it and pushing it... might as well go ahead and build it for bigger nitrous, because its not going to change the price.
If you're going to spray the car...iron block all the way. Mine was built down in Texas by company called ARD. 11.5:1 compression, Callies internals, etc. As I said let me know if you want to take a look at the build specs.
Why is it bad to use spray on the alum block?
Maybe FI would be a better option?
I have an old school 383 in my car right now and was looking at the LS2 for the all aluminum block (less weight).
I'll keep it NA for right now and either go nitrous or FI down the road.
I need some suggestions on a custom camshaft grind - I basically need just enough vacuum to run power brakes. My 68' chevelle will be a street / strip car.
