GMPP Front Distributor Setup.. Opinions Anybody???
Old Aug 22, 2007 | 10:51 PM
1QuickT-A's Avatar
Default GMPP Front Distributor Setup.. Opinions Anybody???
I'm thinking about buying the front cover and dist. drive gear as well as a MSD Pro Billet Dist., Blaster II Coil, and MSD 6AL.. Its just seems way to easy though and I'm wondering what the catch is. I have only seen one picture of this type of setup and it wasn't a good pic either so if you have any pics that can help me please post them up or some good links if you don't mind.
Is there some kind of spacer you have to buy for the water pump?? It looked like I could see one in the pic that I saw.. Also, what exactly do you have to do about a balancer with the timing marks on it??
Thanks in advance for any and all help!!
Old Aug 22, 2007 | 10:59 PM
JMBLOWNWS6's Avatar
So your looking for something like this?
Old Aug 22, 2007 | 11:00 PM
HioSSilver's Avatar
why would anyone want to detech these engines??
Old Aug 22, 2007 | 11:03 PM
Phoenix 5.7's Avatar
i did notice that GM themselves had this setup on their twin turbo LSX impala. it could have been to promote the dist setup, but i doubt it. but that car was supposively making 2khp. W2W made 1500hp with the stock truck coils
Old Aug 22, 2007 | 11:25 PM
1QuickT-A's Avatar
Thats not exactly how I see it.. I know carbs pretty good and I can decently tune a carb'ed car all by myself. So, thats the way I'd rather go. I won't have to buy a laptop or tuning software and cables etc etc and rely on someone else to tune it for me every time I change something or when the weather changes. Everything is so much easier to do especially for a race car that doesn't see street time. You can run much more aggressive camshafts without all of the computer controlled bs too. Some of the classes don't allow EFI cars so thats another reason. I'm mainly looking for something thats easier to fool with and this is it for me from what I've seen so far. And damn its gonna be fun makin all the rednecks think I've got a ford motor in my Z28.
Carburators and Distributors work and I think we all have seen how well...
Old Aug 22, 2007 | 11:27 PM
1QuickT-A's Avatar
Yeah thats it, but I don't want to run a manual fuel pump though.. Can you block that off just like an old school motor and run an electric pump?? I'm guessing that you can..
I still want to know what to do about the water pump spacers and the valley plate..
Old Aug 23, 2007 | 09:25 AM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
Valley plate you can use stock. There is a particular water pump you have to run, as the OE LSx pumps will not clear. ATI has the correct balancer. You could block off that fuel pump provision and run an electric, or run the Carter pump that is recommended by GM.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Aug 25, 2007 | 09:28 AM
1QuickT-A's Avatar
Which Ford distributor do you have to use??? Is is the 302 or 351W distributor?? I know that the lengths are different on those because of the different deck heights and I think the gears are different as well..
Old Aug 25, 2007 | 09:48 AM
sroka's Avatar
So whats the total cost on this swap incase my MSD 6010 box doesn't work out for me?
Old Aug 25, 2007 | 10:06 AM
1QuickT-A's Avatar
The gmpp front cover and gear thats in the pic above is $450 from summit.. The distributor is around $230, a blaster II coil is around $50, and a msd6al is like $225... You will also need an ATI balancer which is probably $450 or so. Then you have to change some stuff with the fuel system and the water pump is different as well. I plan to make some spacers to sit my meziere race pump out a little further.
Old Aug 25, 2007 | 10:26 AM
SPDMETL's Avatar
Too bad this can't be done really cheap--like a hundred dollars for the front cover , and then use a junkyard HEI
Old Aug 25, 2007 | 10:49 AM
patriotformula's Avatar
There is a guy online that sells the waterpump spacers... You can use the stock crank with this setup, but it has to be pinned so what a hassle. if you dont have the motor out of the car its not worth it. Either way I would rather just learn how to deal with fuel injection. A buddy of mine has this setup and it hardly seems worth the gains if there are any, especially since he knows carbuerators no better then FI
Old Aug 25, 2007 | 11:31 AM
Hector's Avatar
Advanced Performance Tech ???
Old Aug 25, 2007 | 01:05 PM
JL ws-6's Avatar
Race your car!
you can pin a crank in the car, ATI sells the tool to do it. YOu don't think every guy with a procharger pulled the motor to pin the crank puley do ya?
1quick I totally see your thought as to why this is a good idea, I personally came from carb cars and would probably have a MUCH easier time dealing with stuff if I went to this type of setup, at least as far as tuning goes. Luckily my shop isn't too far from my house and they are always able to accomodate me when I need to have the tune looked at..... because if I was in a situation where I had to tune my own car and there was noone around, I'd go to that in a heartbeat
Old Aug 25, 2007 | 02:10 PM
NO CATZZ's Avatar
I think running a carb with either the MSD 6010 or the FAST XFI is a much better choice. Yes you do have to program them with a computer but it is just a much better ignition system hands down. I have a 'deteched' LS1 with a carb and MSD 6010 and it is super easy to tune.
BPD
Old Aug 25, 2007 | 04:19 PM
JL ws-6's Avatar
Race your car!
A 7AL box would be an even better choice.
Old Aug 25, 2007 | 08:57 PM
1QuickT-A's Avatar
I talked to a guy from Tennessee on the phone that was VERY helpful with this.. He answered all of my questions and also gave me the "do's and don'ts" as well.
He said that the dowel pin thing is bullshit and will end up eating up the key way in your $450 dollar balancer. Luckily I have a Callies crank and its already got a key way in it. He said he loves the setup and he uses a MSD 7531 and everything works perfectly. He is running an iron 402 with ported 6.0L heads, solid roller, 950 HP carb, powerglide with 4.30's full suspension and a 175 shot and knocking down 5.70's in 105 degree weather on 275/60's!!!!
Sounds like it works pretty damn good to me..
Old Aug 26, 2007 | 12:03 AM
ls1 joe's Avatar
I have a belt drive distributor and the msd 7531T on my car and love it. The factory stuff just could not keep up at high rpms. My issue was the resolution of the factory sensors not the energy of the coil.
Old Aug 26, 2007 | 01:04 AM
1QuickT-A's Avatar
And there you have it!
Old Aug 27, 2007 | 10:03 PM
1QuickT-A's Avatar
Anybody have a MSD part # on the ford distributor that is needed???
