ls2 reluctor wheel sizes
Old Oct 4, 2007 | 11:01 AM
itspossible01's Avatar
Default ls2 reluctor wheel sizes
Can some one please explain the differences in reluctor wheel choices for the ls2.
Old Oct 12, 2007 | 03:27 AM
WP01's Avatar
24 and 58...
Old Oct 12, 2007 | 03:52 AM
njc.corp's Avatar
in oz some ls2 also come out with 24 -weird but true-
Old Oct 12, 2007 | 01:30 PM
a10beav's Avatar
I believe a transition began in '05 to the 58 tooth, but in '05 & '06 they were mixed up. Depending on who you talk to, all GTO's were 24 but the Vette's were mixed up, or both were mixed up.
if the connector is black it's 24, if its grey it's 58.
Old Oct 12, 2007 | 10:16 PM
njc.corp's Avatar
Thumbs up
CORRECT 100%
Old Oct 14, 2007 | 10:25 AM
jtl12419's Avatar
The reluctor difference is computer/PCM dependant, not engine/model year.
If you have a PCM programmed for a specific reluctor, you cannot interchange. Its best to know what where the PCM came from and used originally.
Old Oct 14, 2007 | 12:47 PM
a10beav's Avatar
That's not completely true. It really is a factor of the engine and any PCM can be used, the harness is the electrical "key". The harness needs the right plug because the 24 and 58 tooth reluctors have different plugs, they're not interchangeable with the different harnesses.
I have a 24 tooth LS2 with an '04 GTO PCM, but the harness was made for the 24 tooth reluctor.
Old Oct 31, 2007 | 04:22 AM
FastPacedGTO's Avatar
i have a 24 tooth 05 gto crank and a 58 tooth 06 vette crank if that helps.
