LS7 vs L92 interchangeability?
Old Oct 9, 2007 | 07:24 AM
EVOVII_SWE's Avatar
Default LS7 vs L92 interchangeability?
Hi guys,
My first post on here
I’m wondering if an LS7 has the same engine mounts and dimensions as an L92?
The reason for asking is that I’m about to kick off a replica project that will be LS7 powered but I don’t have an LS7 to build the chassis from yet. I do however have access to an L92 crate engine that I could use until I receive the LS7.
So lets say that if I had an L92 chassis with a manual TKO600 transmission could I just drop the LS7 in?
Cheers,
Thomas
Old Oct 9, 2007 | 07:42 AM
Willem @ Fuel Injection Concepts's Avatar
yes, but the oil pan is diff obviously because the ls7 is dry sump. smaller pan.
Skol, (assuming SWE means you're from up there)
Old Oct 9, 2007 | 08:52 AM
EVOVII_SWE's Avatar
Thanks, yes thats correct, I'm from Sweden, getting cold now so locking forward to this project
Old Oct 10, 2007 | 07:51 AM
getting cold here too.. like 5deg celcious right now..
let me know when you need to order the crate ls7
Old Oct 10, 2007 | 10:47 AM
EVOVII_SWE's Avatar
I had 6 degrees C this morning so about the same then
I saw an add over at the Corvette forums where they sold the LS7 in crate for $11,300
http://forums.corvetteforum.com/show...&highlight=ls7
By far the best price I've seen so far.
I'm actually rather ready to order the engine now. But I need a lot of other stuff like the accessory drive with servo pump and alternator, starter, oil tank and oil lines, ECU and accelerator pedal, GM stage 3 cam, titanium retainers, clutch, wheels, Dana 44 axel from a C4, TKO600 transmission, etc etc.
/Thomas
