L92/L76 #' and info please.
Old Oct 14, 2007 | 10:41 PM
WS6HUMMER's Avatar
Default L92/L76 #' and info please.
Ive read the sticky & searched and came up with a few things but the answers I found were a little cloudy & uncertain.
Here's what I understand, PLEASE tell me if I'wrong.
The L92 head's come with 69 cc combustion chaimbers.
What is the intake port volume?
Will LS1 headers bolt up to these heads?
Will anything in the LS1's valve train have to be changed to work with these heads?
Are there any piston to valve clearance with the LS1's pistons on a .608 lift cam?
Will LS1 valve covers work on the L92 heads?
The L76 intake comes with L92 39# injectors.
Is there a stock CABLE actuated throttle body that will work with this intake and if so what size is it and what does it come on?
What MAF are people using with this intake?
Thanks
Hummer
Old Oct 16, 2007 | 11:30 PM
racecar's Avatar
Everything I have heard about L92 is 70cc chambers.
260cc runners.
Headers have the same bolt pattern.
L92 intake rockers are offset.
Old Oct 16, 2007 | 11:44 PM
WS6HUMMER's Avatar
260cc runners.
Thanks for the reply, I pulled out an issue of GMHTP from a few months back and reread their write up about the SLP L76/L92 combo. You really cant beat their deal, they offer the heads with comp 918 beehive springs, and they are decked to change the combustion chaimber volume to 64cc (stock LS1). If your correct on the runner size man thats huge for a SBC. SLP offers their package for around 2400.00 with all the gaskets, seals, and the injector harness adapters, I know what my next purchase will be.
Old Oct 17, 2007 | 08:10 PM
Doc99SS's Avatar
WS6HUMMER: which month was that article?
Old Oct 17, 2007 | 08:50 PM
WS6HUMMER's Avatar
July 07, has a yellow CE T/A with no hood on the cover. Page 40, the article is titled "Sick Flow For Less Dough", very good and informative read.
Old Oct 19, 2007 | 04:34 PM
Doc99SS's Avatar
Got it, thank you.
Old Oct 19, 2007 | 05:12 PM
Johnnystock's Avatar
They wont fit a LS1 or LS6 in stock form or not at all I think. The bore is not the same on the LS2. And you need a gasket fro a 4.065-inch bore. The bore needs to be at least 4.00-inch I think. And watch out for the exhaust port, headers might not fit too...
Thats what I read from GMHigh Tech mag, thats all I know and never heard anyone unsing them on a LS1, because it must be less expensive to get a LS2 stock bottom than having to bore the LS1 to 4.00-inch.
dont forget that you need a L76 intake,and with this, a 90mm TB and it must be cable-wired to fit your F-body(400$ a piece)
It's a cheap and very fast setup, but its for the LS2 guys or similar engine bore...It makes me sick too
Old Oct 19, 2007 | 08:09 PM
Plus, you need to change some rockers...
Old Oct 25, 2007 | 02:50 PM
BLKWS6's Avatar
4.00"+ bore (6.0L+) or larger. wont fit anything smaller due to the intake valve size.
Old Oct 25, 2007 | 03:10 PM
blackbyrd's Avatar
my headers seem to fit fine on my l92s
Old Oct 25, 2007 | 04:43 PM
WS6HUMMER's Avatar
Is this a fact? Can you provide a specific source for your post?
Old Oct 25, 2007 | 06:14 PM
HSV-GTS-300's Avatar
http://www.gmhightechperformance.com...ads/index.html
Old Oct 25, 2007 | 06:25 PM
Here's some of many.
http://www.carcraft.com/techarticles...ads/index.html
http://www.slponline.com/coming_soon_12293.asp
"NOTE: SLP L92 Heads can only be used on LS motors with a 4.000" Bore or larger."
Old Oct 26, 2007 | 09:08 AM
WS6HUMMER's Avatar
Very informative, very good reads. Thanks for posting them up, I'm a beleiver now.
Old Oct 26, 2007 | 12:18 PM
LightFighter's Avatar
don't get your combo from SLP unless you want to spend more money for no other reasone
Professional products makes a Cabled LS2 TB thats 91MM, or 96MM I think they go for around 200 bucks
Old Oct 26, 2007 | 12:22 PM
WS6HUMMER's Avatar
Good info, didnt know about that TB.
Old Oct 30, 2007 | 09:41 AM
BLKWS6's Avatar
Yes, this is fact. Just do a search for them or read the L92 sticky. All the info you could need is in there.
Old Oct 30, 2007 | 10:05 AM
69LT1Bird's Avatar
I have never seen a Professional Products cable operated throttle body that will bolt to the 4 bolt style L76 intake. Do you have a part number? I will buy it today if it exists.
Old Oct 30, 2007 | 10:06 AM
WS6HUMMER's Avatar
Thanks, yeah I found that out last week, at least I know now. Back to the drawing board, lol.
Old Oct 31, 2007 | 09:55 AM
BLKWS6's Avatar
yeah..its sucks. There have been rumors of small bore L92 style heads coming from GM but nothing concrete yet.
