LS7 heads on a Iron 408 LS1
Old Oct 30, 2007 | 02:40 PM
bottlebabyWS6's Avatar
Default LS7 heads on a Iron 408 LS1
LS7 heads on a Iron 408 LS1. Basically I have a 408 with AFR 225 heads and fast 90/90 set up and am thinking about going this route instead of the AFR heads. Does anybody have any information on what is invovled indoing this besides the intake manifold and heads themselves. Any help would be appreciated thanks guys.
Old Oct 30, 2007 | 02:52 PM
Stang's Bane's Avatar
You would need the ET 4" bore ls7 heads. Rocker arms are different. Check for custom pushrod length.
Old Nov 12, 2007 | 10:21 PM
Troux's Avatar
Apparently the FAST doesn't work with LS7 heads.
Old Nov 12, 2007 | 10:53 PM
LASTLS1's Avatar
6 Second Club Moderator
They work pretty good. You need LS7 rockers too.
Old Nov 12, 2007 | 11:29 PM
DVS99TRANS's Avatar
I thought it was a recommended 4.000 bore for L92 heads and 4.120 with LS7s??? That's what I've been told, could be wrong
