need help. ls3/l92 or lsx
Old Nov 3, 2007 | 09:24 PM
Big Bird WS6's Avatar
Default need help. ls3/l92 or lsx
Need help here guys. please help
[u]APS TT Kit Setup[/U}
Year Make Model: 2002 CETA
Engine-
Block(CI):ls3/l92 stock cube or lsx around a 370 cubic inch. ------------? this is where i need the help. anyone please
Compression: 9.0 or 8.5 to 1 -------------?
Oiling: stock style------------?
Crankshaft: callies
Connecting Rods: callies
Pistons: Diamon
Cylinder Heads:afr 225 ported by tony m
Camshaft: ????????
Rocker Arms: stock
Intake Manifold: either fast 90 ported by tony m or wilson manifold--------?
Ignition/Computer: stock
Exhaust: custom
Cooling System: stock
Fuel-
Pump: twin intank 255
Injectors: 85---------? need to find high impedance
Rails: fast
Drive train/Transmission-
Transmission: rebuilt t-56
Clutch/Converter: tex
Driveshaft: steel / carbon fiber if money is left
Rear Axle: new moser M9
Chassis-
Front Suspension: umi k-member and a-arms
Rear Suspension: DKT Performance Lca and panhard
Brakes:
Performance-
Boost: 18 lbs
Horsepower: (XXX rwhp) wish i knew
Torque: (XXX rwtq) wish i knew
goals are a god street car at 12 psi. and a track god at 18psi
800 is on horse and around that for torque
Old Nov 4, 2007 | 06:50 PM
bump please help
Old Nov 6, 2007 | 09:17 PM
please help
Old Nov 7, 2007 | 10:36 PM
V8Rumble's Avatar
I think it would help if you could post exactly what your goals are, how the vehicle will be used - and exactly what your questions are...
No offense, but there's nowhere near enough info provided for anyone to even hazard a guess...
Old Nov 7, 2007 | 11:56 PM
edited thanks agian
Old Dec 3, 2007 | 04:48 PM
Cantalope Kid's Avatar
At that power level I would go LSX. Your only going to want more anyhow. The only disadvantage with the LSX is that it requires more money up front to have the reliability/longivity/upgrade options in your back pocket. Also heavier.
I personally would go L92. I like aluminum blocks and don't need 800hp on tap to kill myself with.
Old Dec 4, 2007 | 09:35 AM
merriman44's Avatar
What he said^. If you want big horse easiest way is to stroke it and then add your blower. Just do a LIGHT line honing of the L92 block to true up the cylinder walls. This will way you can maximize your wall thickness. Ls2 blocks are pushing over 1000 horse and the L92's are even stronger. You'll probably be fine.
Why do you want 800 horse? Unless its a drag car you won't need that much. A little of info on your background might help us guide you as well
Old Dec 4, 2007 | 10:57 AM
toneloc60's Avatar
What are you going to do the most of with the car? Street or strip? If it's going to driven hard on the road a lot, I say LSX. If you're going to be more conservative on the street with most of your hard driving on the strip, or doing autocross, I say L92.
Personally, I'm building a street car that will see occassional strip use with a NA goal of 650 rwhp and adding a 300 shot. Because of the desire for large nitrous shots, I'm building an LSX. You can't beat the reliability of it, and I don't care about weight. I'll take the small hit on my E.T. to ensure I can keep running it over and over for years.
Old Jan 8, 2008 | 12:31 PM
i want a street car with some track use. but a hell of a lot of street races. lol
so i thnk i might go with the lq9. but i don't know. cuase i think with all the right internals the ls3/l92 will hold 1000 horse just fine.
Old Jan 9, 2008 | 09:20 AM
99blancoSS's Avatar
lq9 for boost. You get all the hp you want from it
Old Jan 10, 2008 | 02:21 PM
but if my max goal is only 1000. then wouldn't the aluminum ls3 be just fine?
Old Jan 10, 2008 | 02:26 PM
99blancoSS's Avatar
iron is better, more durable, doesnt distort. This means longer life for the engine.. Its also cheaper. This is the prefered block if your going to boost. Iron also does something with the heat in the cylinder. I'll butcher this but its heat retention which help to maintain power. I've seen it explained, I cant explain the physics behind it but it was worth 15 hp.
Old Jan 12, 2008 | 06:59 PM
RAGENZ28's Avatar
+1 same thing applies to heads, running an iron head vs. aluminum head that flows exactly the same, the iron head will make more power.
