416 Headers L92
I would do a 1 7/8" with a 3" Y pipe stepped to a 3 1/2" outlet. Should be a very nice combo. Now if you’re going crazy on spray or trying to make HUGE power with LS7 style heads, huge cam etc then that could be a different story. Maybe then you would want a 1 7/8" header with a custom 3 1/2" "Y" pipe to a 4" outlet.
We can get you whatever you need from American Racing, and more than likely have it in stock.
We are having a sale right now on their product. Check it out below.
Thanks
Jeremy
https://ls1tech.com/forums/sponsor-sales-specials/806949-american-racing-headers-halloween-sale-mph.html
Thanks
Jeremy
https://ls1tech.com/forums/showthread.php?t=806949
They do make a 3 1/2" to 4" "Y" pipe and are making one right now for a customer that ordered last week.
They do a custom merge so you don't have that raspy sound, leaks, etc and the product is top notch. The price however is much greater when you get into the 1 7/8" stepped and the custom "Y" pipe's.
If you are making the power to need this kind of header/Y pipe then I believe ARH will be the best system you could choose. The product is unbeatable.
Send me a email @ JZ@mphparts.com and I will do my best to get a few pictures for you and go over cost on these systems.
Thanks
Jeremy
I still feel 1 7/8" is a great headers do go with and enough for your NA motor. We have done 3 ported heads/ L92 motor's now and the best power was 551.7... He has 1 3/4" ARH headers, which just goes to show that the combo is working and I doubt the 1 3/4" are holding him back much.
Jeremy
2003 Z06
12:1CR
TEA ported L92's with a L76 intake, and a ported LS2 TB.
250/258 duration cam, 620ish lift on a 113+0
ARH LT's with non catted X pipe, and Borla Exhaust
Ele Water pump, vararam, cometic .045 gaskets.
93 octane. Dynoed on a dynojet 248C with a spec stage 3+ and alunimum flywheel.
He now has a steele flywheel and a heavier rear time and made 533 a few weeks back.
But says it feel's stronger. HAHA go figure.
hate to do this to you as you already have a strong running car but have you considered the 4" bore ETP LS7 heads? You will gain between 15-30 CFM's through the manifold using the LS7 style ETP heads and a ported LS7 intake manifold over what you have now. The manifold is really a killer of power, especially past 6,200 RPM's.
