Harland Sharp L92 Roller Rockers
Does anyone have any info on the new Harland Sharp RR's to suit a L92 head ?
I did hear they were available but as yet can't find any details on them.
Any help would be much appreciated.
cheers
cheers
they are doing stock LS7 rockers for $250 ish. came highly recommended by both steve at R.E.D. and Richard of WCCH.
www.harlandsharp.com
This came from HS on 11/26
I included his contact information if you wanted to talk to him directly.
We have developed a roller rocker system for the L92 heads and to the best of my knowledge the LS3 uses the same head. The only mods that need to be done are extra clearance on the head, around the pushrod side of the rocker. For a 1.8:1 ratio you need to order part# SL928 and the cost is $535.00. I can ship a set in about a weeks’ time. Thanks
Randy Becker Jr.
Harland Sharp Roller Rockers
19769 Progress Dr.
Strongsville, OH 44149
(440)238-3260
Randy Becker Jr.
19769 Progress Dr.
(440)238-3260
Yep thats almost the same email I got from Randy Becker. Heads will have the notches done by Richard from WCCH but for the moment I will keep the stockers in there and let someone else test the Harland Sharps
cheers
cheers
When my 416 L92 was built, there was only two options. 1. use the stock L92 rockers, and 2. have Harland Sharp upgrade the stock rockers. I went with option 2, so far s good.
I have a set of stockers from my 317 heads that I pulled to make way for the L92's. Can I use these on my new heads? (except for the new 8 offset ones I need) and what does H-S do to the stockers to improve them, and lastly what is the cost? Thanks
Correct, you can use the 8 stock (317 heads) rockers on the exhaust valves. You will need the new offset rockers and pedistals for the L92 heads though.
