LS7 Intake Manifold Options
Old Dec 16, 2007 | 09:25 AM
STROKER R/T's Avatar
how much power do you think is in porting a intake after buying all the best parts to build a high dollar race motor..if you make 5 your lucky !!! that's my point ...if the best $3000 sheetmetal maker's in the bissness are only making 20/30 hp on $20.000 / 8000 rpm motor ...your not makin 20 hp out of portin ..so don't think GM left all that hp on the table..plastic has edges clean them up... it all help's ..but holly !!! don't kill the mesager !!!!
Old Dec 16, 2007 | 04:15 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
I've dyno tested a few hyped up ported ls7 intakes & they seem to show about 7hp gains from what I've seen. I can track down some of my engine dyno sheets for you guys if you'd like....
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Dec 16, 2007 | 04:23 PM
scott_mckinney's Avatar
Hi Jason. Who did your porting? Did you port the manifold & throttle body?
Old Dec 16, 2007 | 04:31 PM
i got 5 rwhp !!! 3nd year on my ls2 seaved 427 vette comming up !!!http://s97997631.onlinehome.us/temp/...nale/web.wmvso .. enjoy the last run in 2007
Old Dec 17, 2007 | 08:48 AM
toneloc60's Avatar
dude, nobody is making fun of you so don't take this the wrong way... You're grammar needs a lot of work. If you put an effort into what you write we'll all be able to understand it. If you're not going to put forth that effort, it's about useless to post because we don't understand what you are trying to say.
Old Dec 17, 2007 | 10:23 AM
hardtop ss's Avatar
If that all you picked up from your ported intake,somebody need to do more homework on porting.I've never had one pick up less than 8 rwhp.
Old Dec 17, 2007 | 10:25 AM
Argon Z's Avatar
Does anyone know the runner length on stock ls7 intake
Old Dec 17, 2007 | 10:30 AM
Argon Z's Avatar
https://ls1tech.com/forums/showthrea...431&highlight=
Look at the above link
Old Dec 17, 2007 | 11:18 AM
LILS's Avatar
https://ls1tech.com/forums/showpost....04&postcount=3
But, as you already well know, knowing the runner length without knowing the taper angle isn't entirely useful.
Old Dec 17, 2007 | 11:44 AM
hardtop ss's Avatar
[QUOTE=hardtop ss;8319674]If thats all you picked up from your ported intake,somebody need to do more homework on porting.I've never had one pick up less than 8 rwhp.
Old Dec 17, 2007 | 01:06 PM
So who does the best porting work then?
Old Dec 17, 2007 | 02:15 PM
  #32
Wnts2Go10O's Avatar
if the sheetmetals arent living up to the hype, you think an ITB would be better for these N/A race motors? if youre only seeing those small gains i would think its not the manifold but the TB reaching its limits.
Old Dec 17, 2007 | 02:54 PM
  #33
hardtop ss's Avatar
A 90 mm T-body is good for well over 800rwhp, the Ls7 intake is about maxed out a little over 600 rwhp NA.
Old Dec 17, 2007 | 02:55 PM
  #34
Hi. So for an LS7 engine with twin turbos and nitrous, what intake manifold would you suggest?
Old Dec 17, 2007 | 03:10 PM
  #35
hardtop ss's Avatar
Im sure with turbos the intake would be fine.If you need nitrous along with turbos to make the power you want,you might want to rethink your turbo size(unless your just spraying the intercooler).
Old Dec 17, 2007 | 05:02 PM
  #36
[QUOTE=hardtop ss;8320065]
not to bust in but how many built motors did you dyno first then port then dyno agin ...do you have any real proof of 8 rwhp ..side note !!! do not wish to have tuner war or discredit but i have done testing and there is 5 hp if that !!!
Old Dec 17, 2007 | 05:22 PM
  #37
hardtop ss's Avatar
I have done tons of before and after dynos.Alot of customers want to see the gains.
Old Dec 17, 2007 | 05:56 PM
  #38
ok !!! you win !!! thats proof !!!
Old Dec 17, 2007 | 06:06 PM
  #39
hardtop ss's Avatar
Look on corvette forum Vette-air has shipped ported intakes all over the world to independant shops and individuals that have dynoed 10-12 rwhp.I dont know what else to say.
Old Dec 18, 2007 | 12:28 AM
  #40
I appreciate everyone's help! Anybody using any aftermarket injectors on their LS7?
