Can someone confirm me that those are ls2 coils please
Ok i ll make a long story short.
I got a lt4 vette engine and im converting it to a 8 coils system(ltcc system).It can work with ls1 coils or the ls2 coils when shipped with the correct harness.
I just want to confirm that these coils are ls2 because why buy some used ls1 when i can have some brand new ls2 for dirt cheap .
Thanks
http://cgi.cafr.ebay.ca/NEW-LS1-LS2-...sid=p1638.m118
***You are bidding on BRAND NEW OEM DELPHI IGNITION COILSET OF 8
Most people are using this coils to convert Ignition System LS1 to New style Ignition System LS2 to get efficiency less energy better Spark.
The new engine LS2 with 400 peak horsepower - The highest standard horsepower ever offered on the Corvette.
Also can be installed on 325 5.3L 364 6.0L and 8.1L Vortec Truck Engines Silverado, Sierra, Tahoe, Yukon, Denali, Escalade, Avalanche, & Hummers.
Coils are new, never used before
These Coils produce 90 mJ
Voltage 40 Kv each coil.
Bracket and wiring harness ARE NOT INCLUDED.
AC DELCO # D514A
STANDARD # UF414
GM # 12573190
Thanks
AC DELCO # D514A
STANDARD # UF414
GM # 12573190
OWN3D BY MY PROF!
It would help if the site you quoted wasn't in french. Try regular ebay, I see them on there every once in a while. From what I can tell the AC Delco number isn't complete. There's some letters that go after the last A. What I can tell you from searching that part number is that it is a 2005-2006 coil. I've got a few descriptions though that might be able to help you.
ROUND SHAPED COILS 12573190
This guy says that part number coil is off of a LS2 crate engine, but then again he wants $600 for some stock LS2 exhaust manifolds.
http://edmonton.kijiji.ca/c-cars-veh...QAdIdZ16733363
Some useful coil info:
http://www.ssrfanatic.com/forum/f5/q...can-help-7930/
