Help fast intake doesnt fit my c6!!!
we tried to fit the fast 90mm intake but the intake hit the back wall of the car,( behind the intake )there is not enough space for it to fit .
i thought the fast intake is universal it fits ls1 and ls2 right !!??
i dont wanna dig or cut or touch my body the car is still new and in the other
side i dont wanna cut my intake or do something with it .
plzzzzzzz help
C6 Corvette Map Sensor Relocation Kit
PN: 54029
MSRP: $124.68
LSX C6 Corvette Firewall Clearance Kit
PN: 54030
MSRP: $83.93
LSX to LS2 Fuel Rail Adapter Kit
PN: 54026
MSRP: $99.33
Here is a good writeup with detailed pictures of the firewall modifications you'll need to perform.
http://www.vetteweb.com/tech/vemp_07...old/index.html
plzzzzzzz help
goodluck with the install
Its called a firewall install kit it sells for 125 dollars.
but what is the LSX to LS2 Fuel Rail Adapter Kit is it a adapter that will work with my stock fuel rail !!!
i did a small search and found that my stock injectors wont fit also !!! something about o -rings and some threads saying to throw the ls2 injectors and put the ls1 injectors!!!
and how does it look i did a search in 20 sites and couldnt found any pic .
grrrrrrrrr this intake makes me feel mad too much work and any small mistake will destroy the whole thing /
Does it have heads and cam already?
The reason I ask is, if not, the minimal gains from this intake may have you really banging your head after it is installed....there are some nice numbers being put up by ported LS2 intakes, and they fit....
but guys will i need to do some job to my injectors ??
The LS2 intake has a larger injector opening in the intake base for the O-ring so the LS2 injectors with the factory O-rings will be too tight a fit into the FAST intake.
If you are using non-stock injectors, then you may be able to use the existing O-rings on the injectors depending on the type of injector.
The FAST intake was designed before the LS2 and the C6 Corvette came out so it was designed to replace the LS1/LS6 intakes so it fits under the hood of a C5 Corvette and it has the injector bore machined for the LS1/LS6 style injectors (and the more common injector/O-ring OD found on those injectors).
BTW - a stainless fastener kit is also available for the FAST intake.
