injectors and rails for L92 carb intake ?
Old Jan 23, 2008 | 04:40 PM
3timeracin's Avatar
Default injectors and rails for L92 carb intake ?
I am in the process of converting an iron 408 ls1 with a fast plastic intake fast rails and fast injectors over to the L92 topend with PRC CNC'd heads GMPP carb aluminum intake this is in a 2000 z28 ss what rails and injectors will I need for the new intake to work with my existing harness ? Thank you in advance
Old Jan 23, 2008 | 09:21 PM
BES Stroked Nova's Avatar
get a set of speed inc ls2 rails. you will need the larger o ring adapters for your injectors which can be found here. http://www.lingenfelter.com/store/v1003.html
and you should be able to figure out the rest.
Old Jan 24, 2008 | 10:54 AM
3timeracin's Avatar
Thumbs up
Thanks I wasnt sure if it was that easy. My rails from fast say ls1 and ls2 in the paper work ? so I thought they might work. I also thought I might need different injectors and the harness adapter most rails for the right spacing of the carb intake are for a different style injector ?
