LS2 GTO Oil pan.???
Old Feb 22, 2008 | 05:30 PM
onestepfurther's Avatar
Default LS2 GTO Oil pan.???
I have a 2007 4.8L out of a Silverado. and i was just wondering if I would be able to use a LS2 GTO oil pan on it.
Will it bolt right up?
Would I need a new pickup tube also?
I'd appreciate the help,
Chase
Old Feb 23, 2008 | 06:50 PM
HSV-GTS-300's Avatar
I don't know if it will bolt right up....but this might help.
You'll need all the following:
Holden front sump oil pan (04-06GTO)
Windage tray
Oil pickup tube
Filter relocation twin pipes
Dipstick tube
Dipstick
Old Feb 24, 2008 | 12:29 AM
Ryne @ CMS's Avatar
LS1TECH Sponsor
no way......... why not just use your original pan?
Old Feb 24, 2008 | 10:33 AM
the motor is goin into a '93 240sx. i doubt the truck pan will have enough clearance
Old Feb 29, 2008 | 12:48 PM
GM_POWER's Avatar
It will bolt right up, you will need a GTO pickup tube.
Old Feb 29, 2008 | 05:26 PM
^thanks man. i appreciate it
Old May 7, 2008 | 07:31 AM
EveeSTi's Avatar
Do you have the part numbers on the pickup tube and windage tray as well? Thanks!
Old May 7, 2008 | 04:46 PM
Kingsize's Avatar
Here you go!
https://ls1tech.com/forums/conversions-swaps/911898-fs-gto-oil-pan-w-windage-pickup.html
Old May 12, 2008 | 10:00 PM
FadedFD's Avatar
Have you started a build thread? I'd like to see this swap.
