ls6 intake on ls2 engine
Old Feb 27, 2008 | 07:27 PM
THEE PEWTER Z™'s Avatar
Default ls6 intake on ls2 engine
My buddy ask me a question that i didnt have an answer for. Performance wise. would the ls6 intake be better for him on his ls2 and what he would need to do the swap... ANY TAKERS
Old Feb 27, 2008 | 07:47 PM
TLewis4095's Avatar
NA the LS6 wins with us, on FI the ported LS2.
Old Feb 29, 2008 | 06:21 PM
ANYONE ELSE? im not in the wrong section am i?
Old Feb 29, 2008 | 06:36 PM
ONEBADASSWS6's Avatar
From what I've heard, the LS6 and LS2 intakes are very close performance wise. Probably not worth doing the swap for the couple HP you would gain.
Old Feb 29, 2008 | 06:53 PM
crazymofo1986's Avatar
will the ls2 and 6 swap for an ls1 no problem
Old Feb 29, 2008 | 07:00 PM
The LS6 is directly interchangeable with the LS1 intake, except for the fact that the LS6 intake doesn't have EGR, and you will need to notch the bottom of the LS6 to clear the LS1 coolant lines. I believe the LS2 intake uses electronic throttle, so I don't think the throttle body and cable bracket would be interchangeable with the LS1 intake.
Old Feb 29, 2008 | 07:44 PM
primer84z's Avatar
Well here was a test done. http://www.gearchatter.com/viewtopic11052.php
showed the LS6 intake to be better at all rpm's, I dont know the particulars of actually doing the swap though.
Old Feb 29, 2008 | 07:48 PM
TiredGXP's Avatar
LS6 is designed for a three bolt 78mm TB, not the four bolt 90mm TB on the LS2 or the four bolt 78mm TB on the LS4.
I haven't found an adapter for the 4 bolt TB's, so I've been building one to mount the LS4 TB.
EDIT: this assumes that you want to keep drive by wire.
Hmmm, I think I remember reading on another thread that the LS2 has different injector spacing. If true, new fuel rails would be required to use the LS6.
Old Mar 1, 2008 | 11:37 AM
Johnnystock's Avatar
true
Plus, the LS6 cant take a 90mm TB(stock on your LS2) and the map sensor is in the rear. Might need an harness adapter from FAST too.
The LS6 is a lot better than a LS2 stock, but the LS2 ported is badass, from what I've heard. check this site http://www.ls2portworks.com/
its onebadws6 that told me these nice infos....
I'm thinking about going for a ported LS2 now...
Old Mar 4, 2008 | 09:36 PM
skyhighsami's Avatar
no title here
If I had a LS1 that I was building for boost would it be worthwhile to install a LS2 intake over the LS6 so I can run the bigger TB? If so what is needed, could I get a NW 90 and bolt it on a LS2 that I had ported? Thanks
Old Mar 4, 2008 | 09:45 PM
no title here
Or would an Edlebrock with an elbow and 90mm TB be better?
Old Apr 3, 2008 | 01:26 PM
fenix999's Avatar
edelbrock with the elbow and the 90mm would probably have more potential and be better off the bat to start with. I can get you those at a very reasonable price. Just PM me with what you'd like to do with the setup...
Thanks
Old Apr 3, 2008 | 02:32 PM
primer84z's Avatar
did you guys miss the link i posted up there? LS6 intake with a 78mm TB made more power than a ls2 with a FAST 90 mm TB. So your not getting any benefit of having a bigger TB on a crappier intake.
Old Apr 7, 2008 | 10:13 AM
OutToWinPAHC's Avatar
Iv posted in the fuel section and have only had 16 hits on the thread. My buddy has a brand new LS2 crate motor and he has allrea1dy pulled the top end off for some upgraded. I was thinking about buying the injectors. He told me 50 bucks for all 8. But I have the LS6 manifold. I just dont know if they will fit. I know the LS2 guys use the LS1 injectors with larger O rings, but are the LS2 injectors too big to fit the LS6 intake and rails?
Old Apr 8, 2008 | 05:48 AM
HSV-GTS-300's Avatar
LS2 injector dimensions are different all over.
You'd have to discard the LS2 lower O rings and use something smaller diameter, maybe LS1 O rings on the lower part of the LS2 injector??
The LS2 injectors are shorter, so you'd have to lower your current fuel rail (by bending it ??).
The LS2 injectors use a different electrical connector, so you'd need a set of 8 injector adapters (about $60) to adapt from LS1 harness to EV6 injectors.
