ls3/l92 ??s
was looking at some cams too...I would assume that I could get good results if I picked up a good working cam that the vette guys are using since it's pretty much the same engine, maybe one of the new Lg cams??
thanks
Other than a couple of small changes the intakes are the same. There is no performance difference between the two manifolds.
Robin
Also, if you have a good cam and the heads reworked (increased compression and exhaust runner work is nice) you can use a ported intake manifold to bring the combo up by at least 10rwhp and possibly more with a very nice torque gain in the midrange.
You should talk to Ed at http://www.thehpfactory.com/ he's a sponsor here and all over the L92 combo's.
