GTO power steering pump
Old Mar 24, 2008 | 02:05 PM
a10beav's Avatar
Default GTO power steering pump
I have a GTO LS2 with stock PS pump and I'm installing a remote reservoir. I'm not able to place the reservoir higher than the pump, so does the stock pump generate enough suction to pull the fluid up a slight incline?
I searched, but found nothing.
Old Mar 24, 2008 | 03:57 PM
JoeMama's GTO's Avatar
Maybe if you prime the pump first... really not sure though.
Old Mar 25, 2008 | 02:46 PM
a10beav's Avatar
I emailed two companies about this. PSC says the pump can be modified to increase flow, and Turn One says it has to be gravity fed.
Nobody has done remote reservoirs with their LSX cars?
Old Mar 25, 2008 | 03:52 PM
ExTurbo's Avatar
im interested in this as well...where are you placng the res? My fast intake is very close to the nipple on the right side of the car, and the PS bracket is almost touching my pulley. Id like to relocate it for safety's sake.
Old Mar 25, 2008 | 05:03 PM
a10beav's Avatar
I'll start a thread with details when it's done. I have it where my battery used to be, but this is in my '88 Firebird.
Right now I'm leaning to sending my pump to PSC Motorsports. They say they have modified these on GTO's with remote reservoirs and hydroboost brakes.
Old Mar 25, 2008 | 06:58 PM
scv8's Avatar
Very interested in the outcome. Thanks.
Old Mar 26, 2008 | 09:04 AM
ExTurbo's Avatar
ah i didnt see it was in a firebird! good luck with it man...
Old Mar 26, 2008 | 10:51 AM
Project GatTagO's Avatar
I have always heard that it has to be gravity fed, but I am no first hand experience with it.
Andrew
Old Mar 26, 2008 | 04:07 PM
a10beav's Avatar
Well, hopefully the PSC mod does the trick. My life could be hanging on this mod, both my steering and brakes (hydroboost) will be affected...
