90mm GM cable driven throttle body?
Old Apr 8, 2008 | 11:03 AM
N4cer's Avatar
Default 90mm GM cable driven throttle body?
Is there any known way to change a DBW 90mm GM throttle body into a cable driven one? I hate to pay the extra loot for an aftermarket TB when it should be so easy!
Old Apr 8, 2008 | 11:49 AM
TLewis4095's Avatar
Not aware of any....and the GM 90 is not a super performer. Porting helps, but by that time you have spent almost as much as a good aftermarket one.
Old Apr 8, 2008 | 12:16 PM
N4cer's Avatar
$10 on sanding rolls? Wow I want an aftermarket one that's barely over $10 + the $50-100 for a used TB. Where can I find them?
Old Apr 8, 2008 | 04:14 PM
TLewis4095's Avatar
You did not say you would do it yourself.....I was assuming buying a stock TB (have never seen a LS2 90 for $50-$100 used) and then paying the going rate of $150 for porting. If you can do them for that price & they are properly done I'll buy all you can make.
Old Apr 8, 2008 | 04:37 PM
N4cer's Avatar
Seriously? My dog could port a throttle body. There's nothing difficult to it.
I'm looking for my first DBW throttle body to try to modify right now. Get your wallet ready. LOL! J/k. I'd love to have one of yours, but the price is just crazy when I can get the PTM 92mm TB AND the 92mm intake for $1100 from TSP for the combo.
Old Apr 8, 2008 | 04:58 PM
bww3588's Avatar
im wanting to go to a 90MM LS2 intake, as i have one sitting on the shelf. but i need a cable driven TB. i guess ill spring for an aftermarket one since ill be upgrading to the FAST 90 intake in the future.
Old Apr 8, 2008 | 05:18 PM
N4cer's Avatar
So if you pull the actuator off, you can't just put a longer arm in it and tack weld a cam to it for your cable?
Old Apr 8, 2008 | 05:48 PM
TLewis4095's Avatar
We see the LS6 intake w/a ported stock TB outperform the LS2 w/a stock TB.....mostly due to the air leakage between the runners on the LS2. The vibration weld is not a good seal. Wait for the FAST....it is still the best performer out there.
Old Apr 8, 2008 | 05:50 PM
355ss's Avatar
How are you going to account for the idle air and the tps?
Old Apr 10, 2008 | 05:21 PM
N4cer's Avatar
That's why I'm asking. I'm thinking surely we can either put the stock ones in somehow with some modification, or just connect those already in the throttle body to the current car's wiring.
Old Apr 10, 2008 | 11:28 PM
RoDan's Avatar
there isnt an IAC valve in the gm 90mm TBs, the computer just cracks the throttle on its own.
Old Apr 10, 2008 | 11:45 PM
N4cer's Avatar
I dunno. You tell me. I have no idea.
