Used LS7: what should I go through
Old Apr 25, 2008 | 12:29 AM
itspossible01's Avatar
Default Used LS7: what should I go through
Picking up a used ls7 with low miles. What things would you check before slapping it in to the car? Thanks in advance.
Old Apr 25, 2008 | 03:25 AM
RoDan's Avatar
Why is the guy getting rid of the motor? I would pull the heads and look at everything, and just generally go through all the basic stuff. See if the cylinders are scuffed or anything...stuff like that. With the heads off it wouldn't be a bad idea get them pressure tested and get the valves lapped if they need it. I'd also slap a cam and associated goodies on it at this time, because you know you will want a cam at some point in the (probably) near future and it is a breeze with the heads off and the motor out of the car.
Old Apr 30, 2008 | 12:04 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
do a compression test and leak down on it before pulling the heads...
Old Apr 30, 2008 | 12:12 PM
RoDan's Avatar
yeah good call on that, I knew I forgot something.
