rear main seal install
This is a pic of the old style seal. Click to see full image. This is a 98-02 seal and is different then the one I have in my engine which has a tendency to weep oil. Infact over 50% of LS2s/LS3s I work on leak out the rear main. Rarely I tune one that isn't leaking. Pitty they don't use the older style seal. I believe the rear cover plate is definately not the issue. A new gasket and some silicon it troublesome spots(from factory they have no sealant). I normalyy put a pit of loctite master gasket on the outer surface of the seal, just a light smear.And I clean the cover with thinners to get all oil residue off. They definately leak out the seal. I have replaced mine twice, Both have "this side out" on them in very small writing. It is weaping again not enough to drip oil on the ground but I can see it coming from the bottom of the bellhousing, more concerned about the clutch.
I will try going inside out with it, see how it looks then and use a feeler gauge to self centre.
Does anyone have a pic of the new seal? And p/n see if the new reverse lip matches up with the ones we have at our local dealer.
Cheers
Joel
The felpro ones were thicker and completely filled in the area.
The original oem one had a thick metal lip that also filled in the complete area of the rear cover.
Also how much rtv is required to add onto the lower portion of the rear cover *where it meets the oil pan
12639250
Tipsy
