Need help..LS2 injectors
Old May 15, 2008 | 10:18 AM
TurboLark's Avatar
Default Need help..LS2 injectors
Tried to find this info, but had no success.
What size are the LS2 injectors? What N/A HP do they support?
What is a complete intake with rails and injectors worth?
Thanks for the help.
Phil
Old May 19, 2008 | 07:25 AM
HSV-GTS-300's Avatar
34 lbs/hr @58psi
about 500 fwhp
89017648 – LS2 intake manifold – 290ish
12570790 – LS2 throttle body – 360ish
12572174 – LS2 fuel rails – 150ish
89017587 – LS2 injector o-rings – 30ish
12569113 - LS2 injector (8x) - ???
Stock injectors on 2005-2007 LS2 V8 equipped C6 Corvette, 2005-2006 LS2 equipped GTO and 2006 LS2 equipped CTS-V as well.
The LS2 injectors flow 33.9 lbs/hr (4.27 grams/second) at 58 psi (400 kPa) fuel pressure.
LS2 Injector information
Bosch part # 0 280 158 049
GM # 12569113
USCar connector
65.2 mm overall length
52 mm O-ring to O-ring
4.3 mm tip length
15 degree spray cone
4 hole injector
high impedance
The USCar connector is not the same type of connector as used on earlier LS1 and other GM V8 engines so these injectors are not compatible with the older vehicles without changing the connectors on the wiring harness. The injectors are also shorter than the LS1 style injectors and the O-ring diameter in the intake manifold is different as well.
LS2 throttle body attachment fastener x4 = 11519971
LS2 throttle body attachment seal = 12576549
LS2 MAP sensor = 16212460
LS2 intake to cylinder head gasket x8 = 12580833
LS2 intake manifold attachment bolt x10 = 12552344
LS2 fuel injector retainer clip x8 = 24503227
LS2 fuel rail attachment bolt x4 = 12590276
