fast 33lb 58psi injectors should be ok for a 402cid
should the FAST 33lb 58PSI injectors be ok to run with a ls2 intake and fuel rails ? or should i really get a bigger 42lb ? i am not doing much more with my engine , so i would think 33lb 58psi's should be ok ? i also have stage 3 patriot heads ..
calculated fuel injectors
from the calculator 525hp to the flywheel says that 100% duty cycle would be 32.81lb/hr fuel injectors , so if i was going to go with 100% duty cycle at WOT with these FAST 33lb/hr ("346.5cc/min") at 58psi , injectors they will work , but thats the max right ??
I dont understand the old fuel pressure from the new ? i thought the 99 Trans am Stock fuel pressure was 58psi ?? if so will that mean these injectors will be bigger then 33lb/hr then ??? what would they be ?
