cylinder head coolant cross over
Old May 29, 2008 | 10:14 PM
blackbyrd's Avatar
Default cylinder head coolant cross over
will the ls1 crossover fit the l92 heads?
Old May 30, 2008 | 11:14 AM
lt1camaro95's Avatar
I was tempted to say screw the crossover and use two more of the vent blockoffs like on the back of the heads. I dont know if that would hurt though. I believe the 92 are in the same location so it should fit
Old May 30, 2008 | 11:34 AM
blackbyrd's Avatar
arent they reverese flow coolant so it needs the crossover to let the air out of the system, i have the ls1 one on my l92's but its leaking pretty bad
Old May 30, 2008 | 12:14 PM
JonCR96Z's Avatar
LS1s don't have reverse flow, but to answer your question yes it will.
Old May 30, 2008 | 01:26 PM
blackbyrd's Avatar
hm i wonder why its leaking then. thanks guys guess i could loosen them the retighten
Old Jun 2, 2008 | 05:21 PM
blackbyrd's Avatar
there isnt a gasket set for them is there
Old Jun 2, 2008 | 08:12 PM
JonCR96Z's Avatar
Yeah.
Old Jun 2, 2008 | 08:48 PM
69LT1Bird's Avatar
reverse flow has them too. The crossover is at the rear instead of the front.
Old Jun 2, 2008 | 09:34 PM
blackbyrd's Avatar
so there was a gasket kit that explains everything
Old Jun 2, 2008 | 10:37 PM
HSV-GTS-300's Avatar
12551933 - GM Coolant Air Bleed Pipe Seal
Old Jun 3, 2008 | 07:09 AM
blackbyrd's Avatar
damn you the man
