update on 454 problems!!!
Old Jun 9, 2008 | 02:48 AM
camsom's Avatar
Default update on 454 problems!!!
well i did the compression test and sent them to Texas speed and no reply cant get a call back no pm's nothing. bought a 14,000 dollar that lasted a week and now they don want to talk to me. Anyway any suggestions on someone to rebuild this short block for me ?
Old Jun 9, 2008 | 06:04 AM
Deeavi's Avatar
Be patient. Things will work out. Keep calling and emailing them. Everyone is busy this time of year!
Old Jun 9, 2008 | 06:13 AM
Navy David SS's Avatar
I copied this post over to the Sponsor Forum. I'm sure that Texas Speed will step up
David
Old Jun 9, 2008 | 11:15 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
As posted in Sponsor Feedback:
I sent you a reply email last week concerning your email you sent me. I guess I can just post up here so we can discuss this thing online.
This engine was broke in, dyno tested and chassis dyno tested all here in Lubbock. The engine never had any issues of any sort until the day you called thinking the valve train was making some extra noise.
Without anyone ever checking the lifters for issues, I gladly sent you a new set of Caddy lifters to replace the set that you never even bothered to check. If you will remember correctly, the lifters were on back-order from GM so we had to wait a little bit of time to get them. During that time, you constantly drove the car even though I expressed deep concern about the problems this could cause. On top of these issues, you continued to drive the car for several days even after the new lifters arrived.
Despite these blatant oversights in the overall safety of this engine, I still replaced the lifters, custom $100 intake valve, custom retainers, and gaskets to solve the issues caused by YOU driving the car with valve train issues.
I decided that even though you blatantly disregarded my recommendations not to drive the car with possible valve train issues that I would go ahead and replace the damaged components to get the engine back on the road.
Now here we are 6 months+ (not 1 week) into the engine being installed & tuned in the GTO & you've managed to create some additional issues with the engine.
From what you told me a week or two ago the engine did not have these smoking out the breather issues until after you reassembled it following the valve train fixes.
I really don't know what could have been done to cause these issues to pop up immediately following disassembly and reassembly at your shop, but it is something that needs to be researched.
You've decided to drive the engine with suspected hurt lifters, somehow managed to cause the engine to severely smoke out the breather immediately following your reassembly, and attempted to blame a sponsor for issues beyond their control. Can you see the source of my frustration?
You specifically told me the engine smokes out the breather so bad immediately following your reassembly that you couldn't see to drive the car. This is an extremely large amount of smoke coming from a breather installed on the valve cover. How this happens immediately after reassembly is beyond me...
We've had customers install ballooned converters, assemble combos with bad p/v, even forget some of the oiling components and we helped them out every possible way we could. Our dedication to the customer will never change, but at some point guys have to take a little bit of responsibility for the actions that they choose.
With the engine being broke in, engine dyno tested, chassis dyno tested and inspected here at our shop I'm very confident that the engine should have never had any issues. An engine that makes 750 flywheel horsepower and does not smoke out the breather on the dyno does not just decide to die for any reason at all. I think we're going to find that something caused these issues to pop up if we take some time to research the things done to the engine that led up to these issues.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Jun 9, 2008 | 12:39 PM
camsom's Avatar
ok guys i apoligize for starting this thread that way i would just like suggestions on who would be the best shop to rebuild the short block for me ? as far as arguing with a shop i wouldnt have a chance even if i was right so that is pointless. I feel that i got screwed and that's my personal opinion. after dealing with this for six months i would just like to rebuild the motor and actually enjoy it for once! Thank you for any suggestions you may have!
Old Jun 9, 2008 | 01:34 PM
CalSpeedPerformance's Avatar
I would suggest you send it back to TSP for inspection, if they find the cause was on your end, you should pay for the costs of repairing it. If it is on their end, they will fix it for free.
Easy solution.
Old Jun 9, 2008 | 05:22 PM
TVWilkes's Avatar
After reading how far TSP went out to help you with this engine, I do not agree that you were screwed. If I had spent the money for this combo, I would have stopped driving the car the minute that I heard the noise. It seems to me that you are stupid for continuing to drive the car when it was making valve train noises. How can you blame this on someone other than yourself?
Old Jun 9, 2008 | 11:18 PM
camsom's Avatar
Jason i have not received an email from you may have wrong address or something. Anyway point taken guys for the record caddy lifter died less than a week after being tuned and a bit was six weeks of being on back order. During that time i called Scoggin and DIckey twice and they said they had the lifters both times i called which i mentioned to Texas speed and it still took six weeks. Car was driven a total of about 15 miles after first starting to hear the tapping only because it was my only car at the time not cause i wanted to. Anyway after having to wait that long for lifters i will not send the motor back. I would be afraid of how long it would take to fix it. I may be in the wrong like i stated just my opinion. One last question and ill leave this alone just curious to know if someone could tell me about what kind of timing they think this motor should be seeing on pump gas if thats possible to ball park? and thank you to the guys that have offered to help!!!
Old Jun 10, 2008 | 06:09 AM
This post needs to be taken to PM or phone. Both sides have had their say.
David
