For everyone running a stock water pump.
Old Jun 17, 2008 | 07:01 PM
EHPInc's Avatar
Default For everyone running a stock water pump.
Here is another option for controlling engine temperature. These cooling spools replace your thermostat and are currently being used in the NASCAR LS spec classes, Daytona Prototypes, Sand rails and drag cars with great success. Check them out.
http://eleventhhourperformance.com/index.php?cPath=31
Let me know what you think or if you have any questions.
Old Jun 17, 2008 | 08:10 PM
Kingsize's Avatar
How does it work exactly? Thanks!
Old Jun 17, 2008 | 08:50 PM
03 BUSA's Avatar
Also looking for that info.
Old Jun 18, 2008 | 07:41 AM
veee8's Avatar
It is a restricter that replaces the thermostat. C&R also makes NASCAR inline thermostats, but they are a ton of money. I will be getting one of these restricters from 11th hour. Where in MI are you?
Old Jun 18, 2008 | 07:52 AM
EHPInc's Avatar
They replace your stock thermostat and act as a restrictor. We are located in Burton, MI. They can be purchased through our online store, they are in-stock and ready to ship.
Old Jun 19, 2008 | 08:25 AM
Black FormulaLs1's Avatar
are they worth swappin out tho/ is there any significant temp gain?
Old Jun 19, 2008 | 02:18 PM
EHPInc's Avatar
If your cooling system is sufficient, temperature can be raised or lowered depending on the hole size in the spool.
Old Jun 19, 2008 | 03:40 PM
03 BUSA's Avatar
But what are the advantages to this vs a 160 thermostat?
Old Jun 19, 2008 | 06:15 PM
EHPInc's Avatar
The biggest advantage is they won't stick open or closed which can cause you to loose a race or engine damage.
Old Jun 19, 2008 | 07:32 PM
TopFlite's Avatar
Very cool. A manual fan switch and an ACTUAL temp gauge would be a great combination with that. Nice product.
Old Jun 19, 2008 | 07:49 PM
EHPInc's Avatar
Yes it would work well with it. It would allow you to cool the engine below where a thermostat would close. This would be helpful between rounds.
