AEM Pencil coil on LS engines
http://www.aempower.com/ViewCategory...CategoryID=212
those coils were designed for OHC motors that where originally set up for waste spark ignition and want to go to s COP setup, they look to be copies of the Chrysler 300m coils used by the Mitsu and Honda guys.
The company I work for is currently in the works developing a coil for the LS engine and we have similar coils to the AEM pencil coil. The pencil coils will not clear headers, will not fit properly and will not wire up at all.
GM uses "smart" coils which have built in ignitors. The pencil coils in question are dummy coils which do not have the circuitry required to run off the generals ignition system. In order to properly utilize a dummy coil you would need a stand alone inductive ignition system or a CDI box. Neither of which will be easy to adapt properly.
Also, when choosing coils it's important to match the coils with the type of ignition box your using. Typically coils meant for an inductive ignition don't work very well with a CDI ignition and vice versa.
Personally, i'll stick with the $28 each OEM coils that we're running 7.50's@190 with.
Find some of the quickest LSx cars and ask them what they run.
