light weight vibration balancer?
Old Jun 22, 2008 | 12:03 PM
jw33's Avatar
Default light weight vibration balancer?
Does anyone make a light weight balancer for the LSx motors? More specifically an aluminum version of a LS2 GTO balancer?
Old Jun 24, 2008 | 11:33 PM
Pwebbz28's Avatar
http://store.summitracing.com/partde...5&autoview=sku
I believe ls1/ls2 use the same balancer.
Old Jul 1, 2008 | 10:34 PM
CalSpeedPerformance's Avatar
ATI makes an aluminum hub extremely light weight one that takes off several pounds. (race applications only)
Old Jul 5, 2008 | 11:42 PM
ati has one that doesnt run the serpentine belt that is VERY light.
(intended for electric water pump and no alternator
Old Jul 6, 2008 | 11:13 AM
jw33's Avatar
ehhhh, I'd like to find one that is basically a stock replacement that will run all the belts with the correct GTO offset, only lightweight.... I switched over from a regular fluidamper balancer over to a aluminum Romac balancer on the motor I had in this car before and it was pretty noticable.
