no cats and header install on Z06, now hellacious backfire
so i installed kooks longtube and no cats. not i am getting a hellacious back fire. and a flashing CEL light
should i not even plug in the rear 02 sensors at all since i have no cats??
only other possibility is that i have the front and rear connections for 02 sensors mixed up but i dont think that is possible since the 02 extensions had different ends then the old front 02's
thanks alot
If you you have somewhere relatively locally that has a good reputation for tuning Corvettes, take your car there and let them dyno tune your car. That'll clear up how that engine is running after the header install, and that annoying CEL will be no more. Best of all, you'll pick up more power by having the car tuned for the headers.
also took all plugs out, i think one looks like it has a hairline crack in #7 the passenger rear plug. prolly hit it with the old header on the way out
going to get new plugs now then hopefully all is good!
will update in a little bit.
still is backfiring although not as bad or as loud
