Which heads and intake for an LS7 440
I have a fast and milled 225s right now but the heads won't work for the LS7.
What is your recommendation? Ported LS7 and LS7 intake?
Or TFS 235 and ported fast.
http://www.texas-speed.com/shop/item...d=912&catid=40
For just a few $$ more than a stock GM LS7 head we can offer you aftermarket CNC ports (flow figures are listed on that page I linked to) AND a dual spring kit. Think of it as getting an extra 30rwhp for an extra $300 over the stock GM head! We've seen 600+rwhp on several 427 LS7 cars so far with just Kooks headers/X, the PRC heads/cam package, and a ported LS7 intake manifold.
Let me know if I can help with anything you need. We do alot of R&D on these heads with bigger cubic inch powerplants to be sure we can provide some of the best tech help out there to our customers!
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
The aftermarket is going to be more money but you have TFS, All Pro, ET, Dart. The LS7 intake is fairly decent for and OEM intake and comes in a nice package deal from SDPC but then you need an LS7 style head to go with it...like the ET or All Pro or oem ls7 head.
We carry all of the above, if your interested give me a call and I can answer some questions for you. You can make good power with either direction.
Edit: Forgot to mention that power is on pump gas.
